Kensington Wireless Presenter with Green Laser
£61.03
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Backlit button controls move slides forward/back, black out screen and activate the green laser pointer
  • Comfortable grip with special contours for the hand
  • Cursor control joystick lets you use the presenter like a mouse, moving cursor up/down and left/right
  • Green laser pointer is 10x brighter than a red laser
  • Extended 150-foot wireless range to roam the room
  • Internal storage for wireless USB receiver so it wont get lost
  • Stock Status: Clearance
Product codes
Own what professionals use to take control of the room and a laptops cursor with the Expert Wireless Presenter with Green Laser Pointer & Cursor Control. Sometimes pointing just isnt enough. With a simple flick of a switch, you toggle between presentation and cursor control modes. The wireless 2.4GHz receiver stores conveniently inside the remote, and since its uniquely paired, you dont have to worry about device interference. Make your point with a green laser thats 10 times brighter than standard red lasers, ideal for bigger rooms and LED/LCD screens.
Product Description Kensington Presenter Expert Green Laser with Cursor Control presentation remote control - black
Device Type Presentation remote control
Enclosure Colour Black
Localisation Europe
Connectivity Technology Radio
Max Operating Distance 50 m
Battery Pointing device battery
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Wireless Pr...
£61.03
