Kensington Wireless Presenter with Laser
Key features
  • USB receiver deactivates battery when inserted into presenter for storage preventing accidental battery drain
  • Professional high gloss black finish
  • USB wireless receiver stores inside
  • Battery indicator light warns when battery power is low
  • 4GB built-in memory to store your presentations
  • Built-in laser pointer helps you highlight key points
  • Plug & Play operation
  • Easy-to-use 4-button controls
  • Includes 2 AAA batteries and low-battery indicator
  • PC and Mac compatible
Product codes
Here's everything you need to give a great presentation right down to the presentation itself. The Kensington Wireless Presenter with Laser Pointer and Memory features a dongle with 4 GB of built-in memory. The wireless presenter can store hundreds of presentations and it feels great in the palm of your hand. The 2.4GHz wireless receiver has a range of up to 30 feet, and with Plug & Play installation you can get right to your presentation without the need for special software or drivers.
Product Description Kensington Wireless Presenter with Laser Pointer and Memory presentation remote control
Device Type Presentation remote control
Localisation Europe
Connectivity Technology Radio
Microsoft Certification Compatible with Windows 7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Wireless Pr...
