Kensington Wireless ValuMouse
£17.79
Delivery:
Standard: 1-3 working days
Key features
  • Ambidextrous, contoured shape for either right-handed or left-handed users
  • High-definition optical sensor (1000 DPI) for responsive control
  • Plug & Play installation with nano USB receiver
  • Low battery indicator and on/off switch
  • Silent clicking for quiet environments
  • Three Button/Scroll Wheel setup
Product codes
The ideal mouse when you need uninterrupted concentration while working or if you're in a quiet location, such as a library, and don't want to disturb others around you.
Using a compact nano receiver, provides the ultimate freedom and mobility for your mouse with a completely reliable wireless connection so you can always be productive.
The high-definition optical sensor tracks the mouse's movements with smooth accuracy for optimal performance and productivity.
Kensington Mouse for Life - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
Orientation
Right and left-handed
6 cm x 10.8 cm x 3.8 cm
Europe
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Scrolling wheel, battery indicator, on/off power switch, Nano wireless receiver, ambidextrous design, wireless receiver slot
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10
5 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Wireless Va...
£17.79
