Kingston 1.6TB DC400 2.5" SATA 6Gb/s SSD
Key features
  • Consistently high sustained IOPs and low latency
  • Configurable over-provisioning available
  • Enterprise class reliability
Product codes
DC400 SSD
Kingston’s DC400 SSD offers consistent application performance and low latency over a wide range of read/write workloads, and standard as well as user-adjustable over-provisioning to improve random IOPs performance, making it ideal for data centres. Its enterprise firmware improves latency and helps DC400 deliver consistently low data access times under steady state workloads. It’s available in a Performance-Optimised model with greater IOPs for faster application performance and reduced storage latency and in a Read-Intensive Optimised model.
Performance-Optimised model and Read-Intensive model available by special order
Enterprise-class reliability
Legendary Kingston support
Product Description Kingston SSDNow DC400 - solid state drive - 1.6 TB - SATA 6Gb/s
Type Solid state drive - internal
Capacity 1.6 TB
Form Factor 2.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Features Dynamic and Static Wear Leveling, Hot-Plug Support, SmartRefresh, Firmware-based Power-Loss Protection, SmartECC, S.M.A.R.T.
Dimensions (WxDxH) 69.9 mm x 100 mm x 7 mm
Weight 92.34 g
Manufacturer Warranty 5 years warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kingston 1.6TB DC400 2...
