Kingston 120GB SSDNOW UV500 SATA A3 2.5" 6GB/s 256-bit A...
Kingston 120GB SSDNOW UV500 SATA A3 2.5" 6GB/s 256-bit AES Encryption
Select:
Key features
  • Faster
  • AES 256-bit hardware encryption
Product codes
Kingston's UV500 family of solid-state drives dramatically improves the responsiveness of your existing system with incredible boot, loading and transfer times compared to mechanical hard drives. Powered by a Marvell Dean controller combined with 3D NAND Flash for read and write speeds up to 520MB/s and 500MB/s, this SSD is 10X faster than a traditional hard drive for better performance, ultra-responsive multi-tasking and an overall faster system. UV500 provides end-to-end data protection, supports 256-bit AES hardware-based encryption and TCG Opal 2.0 security management solutions. More reliable and durable than a hard drive, UV500 is built with NAND Flash semiconductor memory. There are no moving parts, making it far less likely to fail than a mechanical hard drive. It is also cooler and quieter, and its shock and vibration resistance makes it ideal for notebooks and other mobile computing devices.
Product Description Kingston UV500 - solid state drive - 120 GB - SATA 6Gb/s
Type Solid state drive - internal - End-to-end data protection, Marvell 88SS1074 controller
Capacity 120 GB
Hardware Encryption Yes
Encryption Algorithm 256-bit AES
NAND Flash Memory Type 3D triple-level cell (TLC)
Form Factor 2.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Features End-to-end data protection, Marvell 88SS1074 controller
Dimensions (WxDxH) 69.85 mm x 100.1 mm x 7 mm
Weight 41 g
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
