Kingston 120GB UV500 M.2 2280 6GB/s SSD
£26.37
24 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Ideal for desktops and notebooks
  • Encrypted protection
  • Form Factor: M.2 2280 (double-sided)
  • Capacity: 120GB
  • Interface: Serial ATA-600
  • Type: Internal hard drive
  • Stock Status: In Stock
Product codes
Kingston's UV500 family of SSDs dramatically improves the responsiveness of your existing system with incredible boot, loading, and transfer times.
Product Description Kingston UV500 - solid state drive - 120 GB - SATA 6Gb/s
Type Solid state drive - internal - End-to-end data protection, 3D NAND Technology, Marvell 88SS1074 controller
Capacity 120 GB
Hardware Encryption Yes
Encryption Algorithm 256-bit AES
NAND Flash Memory Type 3D triple-level cell (TLC)
Form Factor M.2 2280 (double-sided)
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Features End-to-end data protection, 3D NAND Technology, Marvell 88SS1074 controller, 256-bit AES
Dimensions (WxDxH) 22 mm x 80 mm x 3.5 mm
Weight 6.6 g
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kingston 120GB UV500 M...
£26.37
