We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Marketing description is not available.
Product Description | Kingston Canvas React Plus - flash memory card - 128 GB - microSDXC UHS-II | Product Type | Flash memory card | Form Factor | microSDXC UHS-II Memory Card | Storage Capacity | 128 GB | Speed Rating | A1 / Video Class V90 / UHS-II U3 / Class10 | Included Memory Adapter | microSDXC to SD adapter | Manufacturer Warranty | Limited lifetime warranty |
General | |
Memory | |
Speed Class | A1 / Video Class V90 / UHS-II U3 / Class10 |
Read Rate | Up to 285 MB/s |
Write Rate | Up to 165 MB/s |
Miscellaneous | |
Included Accessories | microSD card reader (USB) |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Dimensions & Weight | |
Width | 11 mm |
Depth | 15 mm |
Thickness | 1 mm |
Environmental Parameters | |
Min Operating Temperature | -25 °C |
Max Operating Temperature | 85 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
