Kingston 128GB SSDNow V200 SATA 6GB/s 2.5" Solid State D...
Kingston 128GB SSDNow V200 SATA 6GB/s 2.5" Solid State Drive
Key features
  • Performance - enhances productivity; makes users more efficient
  • Innovative - 2.5" form factor; uses NAND flash memory
  • Components - no moving mechanical parts so the SSD handles rougher conditions
  • Silent - runs silent and cool with no moving mechanical parts
  • Reliable - less likely to fail than a standard hard drive
  • Shock-resistant - no moving mechanical parts so the SSD handles rougher conditions
  • Supports TRIM - ensures maximum performance on compatible operating systems
  • Supports S.M.A.R.T
Product codes
Dabs.com Note: Keep Ordering, we have more stock landing tomorrow Friday 29th June
Turbo Charge your PC
Kingston's SSDNow V200 lets you stretch your system without stretching your budget. Designed for notebook and desktop hard drive replacements and upgrades, it maximizes your computer investment while boosting the performance of the system and its applications.
SSDNow V200 makes computers more responsive than ever. Boot up is quicker and applications load faster than ever before. More reliable and more durable than a traditional hard drive, V200 is backed by a three-year warranty, 24/7 technical support and legendary Kingston® reliability.
  • Ideal hard drive replacement
  • Boosts performance, multitasking and efficiency
  • Faster -- boots system and applications faster
  • Reliable -- with no moving parts, solid-state drives are less likely to fail than a standard hard drive
  • Multiple capacities -- to fit your needs
  • Form Factor -- 2.5-inch drive (7.0mm)
  • Silent -- runs silent and cool
Please note this is the standalone SSD: see bundles to attach a half price SATA cable
Product Description Kingston SSDNow V200 - solid state drive - 128 GB - SATA 6Gb/s
Type Solid state drive - internal - TRIM support
Capacity 128 GB
Form Factor 2.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Features TRIM support, S.M.A.R.T.
Dimensions (WxDxH) 70 mm x 100 mm x 7 mm
Weight 88 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
