Kingston 16GB 2133MHz Reg ECC Module Memory
Product codes
Kingston DDR4 16 GB DIMM 288-pin 2133 MHz / PC4-17000 CL15 1.2 V registered ECC for Cisco UCS C220 M4S, Smart Play 8 C240, Smart Play C220 M4, SmartPlay Select C240 M4L
Product Description Kingston - DDR4 - 16 GB - DIMM 288-pin - registered
Product Type RAM memory
Capacity 16 GB
Memory Type DDR4 SDRAM - DIMM 288-pin
Upgrade Type System specific
Data Integrity Check ECC
Speed 2133 MHz (PC4-17000)
Latency Timings CL15
Features Registered
Voltage 1.2 V
Lead Plating Gold
OEM Manufacturer Equivalent Part Number Cisco UCS-MR-1X162RU-A
Manufacturer Warranty Limited lifetime warranty (Russia - 10 years)
Designed For Cisco UCS C220 M4S, Smart Play 8 C240, Smart Play C220 M4, SmartPlay C220 M4S, SmartPlay Select B200 M4, SmartPlay Select C220 M4, SmartPlay Select C220 M4S, SmartPlay Select C220 M4SX, SmartPlay Select C240 M4, SmartPlay Select C240 M4L, SmartPlay Select C240 M4S, SmartPlay Select C240 M4SX
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kingston 16GB 2133MHz...
