Kingston 16GB DDR4-2133MHz ECC Module
Product codes
Kingston manufacture the most reliable memory you can buy for a HP Server. Kingstons legendary reputation is built around reliable memory, that will power your HP server with ease, whether it be for minimal day hours or an enviroment that requires 24/7 uptime all year round. Kingston's legendary reputation is also reflected with the peace of mind of a full lifetime warranty on this HP compatible memory module.
Each chip that is built onto the HP memory board has been scrutnised to the highest level to ensure it meets Kingston's very high quality standards before it enters the manufacturing process. Kingston has developed one of the most advanced testing facilities in the industry for the manufacture of HP server memory upgrades. Kingston employs a multi-tiered testing system to ensure quality control throughout the design and manufacturing process of all HP memory upgrades for Server environments.
Kingston - DDR4 - 16 GB - DIMM 288-pin - unbuffered
RAM memory
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Unbuffered
Voltage
1.2 V
Lead Plating
Gold
HP N0H88AA, HP 805671-B21
Limited lifetime warranty (Russia - 10 years)
HP Workstation Z240; HPE ProLiant DL20 Gen9, ML10 Gen9, ML10 Gen9 Entry, ML10 Gen9 Performance, ML30 Gen9
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Kingston 16GB DDR4-213...
