Kingston 16GB DDR4-2400MHz Reg ECC Module
£178.42
Delivery:
  • Type: DDR4 SDRAM
  • Capacity: 16GB
  • Connection: DIMM 288-pin
  • Speed: 2400MHz
  • Data Integrity: ECC
Product codes
Kingston manufacture the most reliable memory you can buy for a Lenovo Server. Kingstons legendary reputation is built around reliable memory, that will power your Lenovo server with ease, whether it be for minimal day hours or an enviroment that requires 24/7 uptime all year round. Kingston's legendary reputation is also reflected with the peace of mind of a full lifetime warranty on this Lenovo compatible memory module.
Each chip that is built onto the Lenovo memory board has been scrutnised to the highest level to ensure it meets Kingston's very high quality standards before it enters the manufacturing process. Kingston has developed one of the most advanced testing facilities in the industry for the manufacture of Lenovo server memory upgrades. Kingston employs a multi-tiered testing system to ensure quality control throughout the design and manufacturing process of all Lenovo memory upgrades for Server environments.
Product Description Kingston - DDR4 - 16 GB - DIMM 288-pin - registered
Product Type RAM memory
Capacity 16 GB
Memory Type DDR4 SDRAM - DIMM 288-pin
Upgrade Type System specific
Data Integrity Check ECC
Speed 2400 MHz (PC4-19200)
Latency Timings CL17
Features Registered
Voltage 1.2 V
Lead Plating Gold
OEM Manufacturer Equivalent Part Number Lenovo 46W0829
Manufacturer Warranty Limited lifetime warranty (Russia - 10 years)
Designed For Lenovo Flex System x240 M5 9532; Storage DX8200C 5120; System x3650 M5 8871
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Kingston 16GB DDR4-240...
£178.42
