Kingston 16GB DDR4 2666MHz ECC Dual Memory
£95.07
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
  • Type: DDR4 SDRAM
  • Capacity: 16GB
  • Connection: DIMM 288-pin
  • Speed: 2666MHz
  • Data Integrity: ECC
Product codes
Kingston DDR4 16 GB DIMM 288-pin 2666 MHz / PC4-21300 CL19 1.2 V registered ECC
Product Description Kingston - DDR4 - module - 16 GB - DIMM 288-pin - 2666 MHz / PC4-21300 - registered
Product Type Memory module
Capacity 16 GB
Memory Type DDR4 SDRAM - DIMM 288-pin
Upgrade Type System specific
Data Integrity Check ECC
Speed 2666 MHz (PC4-21300)
Latency Timings CL19
Features Dual rank, registered
Voltage 1.2 V
Lead Plating Gold
OEM Manufacturer Equivalent Part Number HP 835955-B21
Manufacturer Warranty Limited lifetime warranty (Russia - 10 years)
Designed For HPE Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10, Medium Solution with HPE ProLiant DL360 Gen10, Small Solution with HPE ProLiant DL360 Gen10; ProLiant DL180 Gen10, DL325 Gen10, DL360 Gen10, DL380 Gen10, DL385 Gen10, DL388 Gen10, DL560 Gen10, DX380 Gen10, ML350 Gen10
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£95.07
