Kingston 16GB DDR4-2666MHz Reg ECC Memory
£111.22
Delivery:
Standard: 1-3 working days
  • Type: DDR4 SDRAM
  • Capacity: 16GB
  • Connection: DIMM 288-pin
  • Speed: 2666MHz
  • Data Integrity: ECC
Product codes
Kingston DDR4 16 GB DIMM 288-pin 2666 MHz / PC4-21300 CL19 1.2 V registered ECC for Cisco UCS C220 M5SX, SmartPlay Select B200 M5
Product Description Kingston - DDR4 - 16 GB - DIMM 288-pin - registered
Product Type RAM memory
Capacity 16 GB
Memory Type DDR4 SDRAM - DIMM 288-pin
Upgrade Type System specific
Data Integrity Check ECC
Speed 2666 MHz (PC4-21300)
Latency Timings CL19
Features Registered
Voltage 1.2 V
Lead Plating Gold
OEM Manufacturer Equivalent Part Number Cisco UCS-MR-X16G1RS-H
Manufacturer Warranty Limited lifetime warranty (Russia - 10 years)
Designed For Cisco UCS B200 M5 Blade Server, C220 M5SX SFF, C240 M5 Rack Server, SmartPlay Select B200 M5 Advanced 1, SmartPlay Select B200 M5 Advanced 2, SmartPlay Select B200 M5 Basic 1, SmartPlay Select B200 M5 High Frequency 3
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Kingston 16GB DDR4-266...
£111.22
