Kingston 16GB DDR4 DIMM 288-pin 2400 MHz/PC4-19200 CL17 1.2V...
Kingston 16GB DDR4 DIMM 288-pin 2400 MHz/PC4-19200 CL17 1.2V Registered with Parity ECC
Product codes
Kingston ValueRAM Server Premier is designed specifically for mission-critical server systems that require maximum uptime and stability. Server Premier Modules are built using the same components every time and include advanced product change notification (PCN). PCN ensures ample time for qualification and testing at the customer site. With ValueRAM Server Premier, you can expect the same degree of reliability and performance that IT professionals worldwide have come to depend on from Kingston memory.
Kingston Server Premier - DDR4 - 16 GB - DIMM 288-pin - registered with parity
RAM memory
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin very low profile
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17 (17-17-17)
Temperature monitoring, single rank, On-Die Termination (ODT), Serial Presence Detect (SPD), sixteen banks, registered with parity
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kingston 16GB DDR4 DIM...
