Kingston 240GB SSDNOW UV500 SATA A3 2.5" GGb/s 256-bit A...
Kingston 240GB SSDNOW UV500 SATA A3 2.5" GGb/s 256-bit AES Encryption
£49.80
11 left in stock
Delivery:
Standard: 1-3 working days
Express: Delivered on Monday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • 10X faster than a 7200RPM hard drive
  • AES 256-bit Hardware Encryption Self-Encrypting Drive (SED) and TCG Opal 2.0
Product codes
Kingston's UV500 family of solid-state drives dramatically improves the responsiveness of your existing system with incredible boot, loading and transfer times compared to mechanical hard drives. Powered by a Marvell Dean controller combined with 3D NAND Flash for read and write speeds up to 520MB/s and 500MB/s, this SSD is 10X faster than a traditional hard drive for better performance, ultra-responsive multi-tasking and an overall faster system. UV500 provides end-to-end data protection, supports 256-bit AES hardware-based encryption and TCG Opal 2.0 security management solutions. More reliable and durable than a hard drive, UV500 is built with NAND Flash semiconductor memory. There are no moving parts, making it far less likely to fail than a mechanical hard drive. It is also cooler and quieter, and its shock and vibration resistance makes it ideal for notebooks and other mobile computing devices.
Kingston UV500 - solid state drive - 240 GB - SATA 6Gb/s
Solid state drive - internal
240 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
3D triple-level cell (TLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
End-to-end data protection, 3D NAND Technology, Marvell 88SS1074 controller
69.85 mm x 100.1 mm x 7 mm
41 g
5 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kingston 240GB SSDNOW...
£49.80
