Kingston’s UV500 SSD dramatically improves your system’s responsiveness with incredible boot, loading and transfer times compared to mechanical hard drives. It uses a Marvell Dean controller and 3D NAND Flash to power through daily tasks and improve productivity. UV500 also provides end-to-end data protection using 256-bit AES hardware-based encryption and support for TCG Opal 2.0 security management solutions. The UV500’s available in multiple capacities from 120GB–960GB1 giving you options to meet your system’s needs.
Product Description | Kingston UV500 - solid state drive - 240 GB - SATA 6Gb/s | Type | Solid state drive - internal - End-to-end data protection, 3D NAND Technology, Marvell 88SS1074 controller | Capacity | 240 GB | Hardware Encryption | Yes | Encryption Algorithm | 256-bit AES | NAND Flash Memory Type | 3D triple-level cell (TLC) | Form Factor | mSATA | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Features | End-to-end data protection, 3D NAND Technology, Marvell 88SS1074 controller, 256-bit AES | Dimensions (WxDxH) | 29.85 mm x 50.8 mm x 4.85 mm | Weight | 6.7 g | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Solid state drive - internal |
Capacity | 240 GB |
Width | 29.85 mm |
Depth | 50.8 mm |
Height | 4.85 mm |
Weight | 6.7 g |
Performance | |
SSD Endurance | 100 TB |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 520 MBps (read) / 500 MBps (write) |
Maximum 4KB Random Write | 25000 IOPS |
Maximum 4KB Random Read | 79000 IOPS |
Reliability | |
MTBF | 1,000,000 hours |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s - 52 pin mini-SATA |
Compatible Bay | mSATA |
Power | |
Power Consumption | 0.5 Watt (average) , 0.195 Watt (idle) , 1.17 Watt (read) , 2.32 Watt (write) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years , Technical support |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 85 °C |
Vibration Tolerance (operating) | 2.17 g @ 7-800 Hz |
Vibration Tolerance (non-operating) | 20 g @ 10-2000 Hz |
