Kingston 240GB UV500 SATA 6Gb/s mSATA SSD
£36.26
20 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Ideal for desktops and notebooks
  • Encrypted protection
  • Form Factor: mSATA
  • Capacity: 240GB
  • Interface: Serial ATA-600
  • Type: Internal hard drive
  • Stock Status: In Stock
Product codes
Kingston’s UV500 SSD dramatically improves your system’s responsiveness with incredible boot, loading and transfer times compared to mechanical hard drives. It uses a Marvell Dean controller and 3D NAND Flash to power through daily tasks and improve productivity. UV500 also provides end-to-end data protection using 256-bit AES hardware-based encryption and support for TCG Opal 2.0 security management solutions. The UV500’s available in multiple capacities from 120GB–960GB1 giving you options to meet your system’s needs.
Product Description Kingston UV500 - solid state drive - 240 GB - SATA 6Gb/s
Type Solid state drive - internal - End-to-end data protection, 3D NAND Technology, Marvell 88SS1074 controller
Capacity 240 GB
Hardware Encryption Yes
Encryption Algorithm 256-bit AES
NAND Flash Memory Type 3D triple-level cell (TLC)
Form Factor mSATA
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Features End-to-end data protection, 3D NAND Technology, Marvell 88SS1074 controller, 256-bit AES
Dimensions (WxDxH) 29.85 mm x 50.8 mm x 4.85 mm
Weight 6.7 g
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kingston 240GB UV500 S...
£36.26
