Kingston 256GB A2000 M.2 NVMe PCIe SSD XTS-AES 256-bit
£37.46
40 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Incredible NVMe PCIe performance
  • Supports a full-security suite (TCG Opal, AES 256-bit, eDrive)
  • Ideal for Ultrabooks and small form factor PC (SFF PC) systems
  • Form Factor: M.2 2280
  • Capacity: 250GB
  • Interface: PCI Express 3.0 x4 (NVMe)
  • Type: Internal hard drive
  • Stock Status: In Stock
Product codes
Kingston's A2000 NVMe PCIe SSD is an affordable storage solution with impressive performance. Boasting read/write speeds of up to 2,200/2,000MB/s1, A2000 delivers 3x the performance of a SATA SSD with quicker loading times, less power consumption and lower heat. A2000 SSD is designed for the entry-level user, purpose-built system manufacturer, DIY system builder and those seeking to upgrade their PC. With a single-sided slim M.2 design, A2000 works to its full potential when installed in an Ultrabook or a small-form-factor PC (SFF PC) system.
A2000 is a self-encrypting drive that supports end-to-end data protection using 256-bit XTS-AES hardware-based encryption, and allows the use of independent software vendors with TCG Opal 2.0 security management solutions such as Symantec, McAfee, WinMagic and others. A2000 also has built-in eDrive support, a security storage specification for use with BitLocker.
Product Description Kingston A2000 - solid state drive - 250 GB - PCI Express 3.0 x4 (NVMe)
Type Solid state drive - internal - NVM Express (NVMe)
Capacity 250 GB
Hardware Encryption Yes
Encryption Algorithm 256-bit AES
Form Factor M.2 2280
Interface PCI Express 3.0 x4 (NVMe)
Features NVM Express (NVMe)
Dimensions (WxDxH) 22 mm x 80 mm x 3.5 mm
Weight 6.6 g
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kingston 256GB A2000 M...
£37.46
