Kingston 32GB DDR4-2133MHz LRDIMM Quad Rank Module
Product codes
Kingston Technology is the world's independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR4 - 32 GB - LRDIMM 288-pin - LRDIMM
RAM memory
32 GB
Memory Type
DDR4 SDRAM - LRDIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Quad rank, Load-Reduced
Voltage
1.2 V
Lead Plating
Gold
IBM 46W0800, IBM 46W0799
Limited lifetime warranty (Russia - 10 years)
Lenovo Flex System x240 M5 9532
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kingston 32GB DDR4-213...
