Kingston 32GB DDR4-2400MHz Reg ECC Module
£144.88
Delivery:
Key features
  • Memory module
  • Registered DDR4
  • 2400 MHz
  • ECC
  • DIMM 288-pin form factor
  • 1.2 V supply voltage
Product codes
Kingston manufacture the most reliable memory you can buy for a Cisco Server. Kingstons legendary reputation is built around reliable memory, that will power your Cisco server with ease, whether it be for minimal day hours or an enviroment that requires 24/7 uptime all year round. Kingston's legendary reputation is also reflected with the peace of mind of a full lifetime warranty on this Cisco compatible memory module.
Each chip that is built onto the Cisco memory board has been scrutnised to the highest level to ensure it meets Kingston's very high quality standards before it enters the manufacturing process. Kingston has developed one of the most advanced testing facilities in the industry for the manufacture of Cisco server memory upgrades. Kingston employs a multi-tiered testing system to ensure quality control throughout the design and manufacturing process of all Dell memory upgrades for Server environments.
Product Description Kingston - DDR4 - 32 GB - DIMM 288-pin - registered
Product Type RAM memory
Capacity 32 GB
Memory Type DDR4 SDRAM - DIMM 288-pin
Upgrade Type System specific
Data Integrity Check ECC
Speed 2400 MHz (PC4-19200)
Latency Timings CL17
Features Registered
Voltage 1.2 V
Lead Plating Gold
OEM Manufacturer Equivalent Part Number Cisco UCS-MR-1X322RV-A
Manufacturer Warranty Limited lifetime warranty (Russia - 10 years)
Designed For Cisco UCS C220 M4S, Smart Play 8 C240, Smart Play C220 M4, SmartPlay C220 M4S, SmartPlay Select B200 M4, SmartPlay Select C220 M4, SmartPlay Select C220 M4S, SmartPlay Select C220 M4SX, SmartPlay Select C240 M4, SmartPlay Select C240 M4L, SmartPlay Select C240 M4S, SmartPlay Select C240 M4SX
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Kingston 32GB DDR4-240...
£144.88
