Kingston 32GB DDR4-2400MHz Reg ECC Module
£188.48
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
  • Type: DDR4 SDRAM
  • Capacity: 32GB
  • Connection: DIMM 288-pin
  • Speed: 2400MHz
  • Data Integrity: ECC
Product codes
Kingston manufacture the most reliable memory you can buy for a HP Server. Kingstons legendary reputation is built around reliable memory, that will power your HP server with ease, whether it be for minimal day hours or an enviroment that requires 24/7 uptime all year round. Kingston's legendary reputation is also reflected with the peace of mind of a full lifetime warranty on this HP compatible memory module.
Each chip that is built onto the HP memory board has been scrutnised to the highest level to ensure it meets Kingston's very high quality standards before it enters the manufacturing process. Kingston has developed one of the most advanced testing facilities in the industry for the manufacture of HP server memory upgrades. Kingston employs a multi-tiered testing system to ensure quality control throughout the design and manufacturing process of all HP memory upgrades for Server environments.
Product Description Kingston - DDR4 - 32 GB - DIMM 288-pin - registered
Product Type RAM memory
Capacity 32 GB
Memory Type DDR4 SDRAM - DIMM 288-pin
Upgrade Type System specific
Data Integrity Check ECC
Speed 2400 MHz (PC4-19200)
Latency Timings CL17
Features Registered
Voltage 1.2 V
Lead Plating Gold
OEM Manufacturer Equivalent Part Number HP 805351-B21, HP 819412-001
Manufacturer Warranty Limited lifetime warranty (Russia - 10 years)
Designed For HPE Apollo 4200 Gen9, 4520 Gen9; ProLiant DL120 Gen9, DL160 Gen9, DL180 Gen9, DL360 Gen9, DL380 Gen9, DL388 Gen9, DL580 Gen9, for Microsoft Azure Stack, ML110 Gen9, WS460c Gen9, XL190r Gen9, XL270d Gen9, XL2x260; SimpliVity 380 Gen9; StoreEasy 3850; Synergy 480 Gen9, 620 Gen9, 660 Gen9, 680 Gen9
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Kingston 32GB DDR4-240...
£188.48
