Kingston 480GB SSDNow mSATA 6GB/s Solid State Drive
Key features
  • LSI SandForce 2241 controller with SATA Rev. 3.0 interface - twice as fast as previous generation, yet more cost efficient
  • mSATA interface - fully compliant with industry standard, easy to fit, guaranteed to work
  • NAND Flash memory based - shock resistant with low power consumption
  • Supports Intel's SRT - combines capacity advantage of HDD with performance improvements of SSD in dual-storage configuration
  • Supports S.M.A.R.T. - monitors the status of your drive
  • Supports TRIM - maintains maximum performance on compatible operating systems
Product codes
Kingston's SSDNow mS200 mSATA solid-state drive oers a cost effective performance boost with a dual-drive option that allows room for adding high-capacity storage. Ideal for system builders, OEMs and enthusiasts, the mS200s ruggedly-cool, miniscule form factor is eight times smaller than a traditional 2.5-inch hard drive, making it perfect for notebooks, tablets and Ultrabooks. Available in capacities of up to 480GB, ms200 has a caseless, PCB-only design with no moving parts and is backed by a three-year warranty (30GB model has a two-year warranty), free technical support and legendary Kingston reliability.
  • NAND Flash memory based - shock-resistant with low power consumption
  • Supports SMART - monitors the status of your drive
  • Guaranteed - three-year warranty (two-year warranty on 30GB), free technical support
Kingston SSDNow mS200 - solid state drive - 480 GB - SATA 6Gb/s
Solid state drive - internal
480 GB
mSATA
SATA 6Gb/s
Data Transfer Rate
600 MBps
Shock resistant, TRIM support, Smart Response Technology, SandForce SF-2241 controller, S.M.A.R.T.
30 mm x 50.88 mm
6.86 g
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kingston 480GB SSDNow...
