Kingston 4GB DDR3L DIMM 240-pin 1600 MHz/PC3L-12800 CL11 1.35...
Kingston 4GB DDR3L DIMM 240-pin 1600 MHz/PC3L-12800 CL11 1.35V unbuffered non-ECC
£19.53
14 in stock
Delivery:
Standard: 1-3 working days
  • Type: DDR3L SDRAM
  • Capacity: 4GB
  • Connection: DIMM 240-pin
  • Speed: 1600MHz
  • Data Integrity: Non-ECC
Product codes
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Product Description Kingston - DDR3L - 4 GB - DIMM 240-pin - unbuffered
Product Type RAM memory
Capacity 4 GB
Memory Type DDR3L SDRAM - DIMM 240-pin
Upgrade Type Generic
Data Integrity Check Non-ECC
Speed 1600 MHz (PC3L-12800)
Latency Timings CL11
Features Single rank, Low Voltage, unbuffered
Voltage 1.35 V
Lead Plating Gold
Manufacturer Warranty Limited lifetime warranty (Russia - 10 years)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kingston 4GB DDR3L DIM...
£19.53
