Kingston 500GB A2000 M.2 NVMe PCIe SSD XTS-AES 256-bit
£58.50
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Incredible NVMe PCIe performance
  • Ideal for Ultrabooks and small form factor PC (SFF PC) systems
  • Form Factor: M.2 2280
  • Capacity: 500GB, 500GB
  • Interface: PCI Express 3.0 x4 (NVMe)
  • Type: Internal hard drive
  • Stock Status: In Stock
Product codes
Kingston's A2000 NVMe PCIe SSD is an affordable storage solution with impressive performance. Boasting read/write speeds of up to 2,200/2,000MB/s, A2000 delivers 3x the performance of a SATA SSD with quicker loading times, less power consumption and lower heat. A2000 SSD is designed for the entry-level user, purpose-built system manufacturer, DIY system builder and those seeking to upgrade their PC. With a single-sided slim M.2 design, A2000 works to its full potential when installed in an Ultrabook or a small-form-factor PC (SFF PC) system.
Product Description Kingston A2000 - solid state drive - 500 GB - PCI Express 3.0 x4 (NVMe)
Type Solid state drive - internal - NVM Express (NVMe)
Capacity 500 GB
Hardware Encryption Yes
Encryption Algorithm 256-bit AES
Form Factor M.2 2280
Interface PCI Express 3.0 x4 (NVMe)
Features NVM Express (NVMe)
Dimensions (WxDxH) 22 mm x 80 mm x 3.5 mm
Weight 6.8 g
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kingston 500GB A2000 M...
£58.50
