Kingston's DataTraveler Vault Privacy 3.0 (DTVP 3.0) USB flash drive provides affordable business-grade security with 256-bit AES hardware-based encryption using XTS block cipher mode, which offers stronger protection than CBC and ECB modes. It protects 100 per cent of stored data and enforces complex password protection with minimum characteristics to prevent unauthorized access. For additional peace of mind, the drive locks down and reformats after 10 intrusion attempts. It also features a read-only access mode to avoid potential malware risks.
Product Description | Kingston DataTraveler Vault Privacy 3.0 - USB flash drive - 64 GB | Product Type | USB flash drive | Interface Type | USB 3.0 | Storage Capacity | 64 GB | Hardware Encryption | Yes | Encryption Algorithm | 256-bit AES | Technology | NAND Flash | OS Required | Microsoft Windows Vista SP2, Linux 2.6 or later, Microsoft Windows XP SP3, Apple MacOS X 10.6.x or later, Microsoft Windows 7 SP1, Windows 8 | Manufacturer Warranty | 5-year warranty |
General | |
Compatibility | Non-specific |
Memory | |
Read Rate | Up to 250 MB/s |
Write Rate | Up to 85 MB/s |
Features | Password protection, waterproof |
Miscellaneous | |
TAA Compliant | Yes |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Dimensions & Weight | |
Width | 77.9 mm |
Depth | 22 mm |
Height | 12.05 mm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
