Kingston 64GB DDR4 2666MHz LRDIMM Memory
£441.15
Delivery:
Standard: 1-3 working days
  • Type: DDR4 SDRAM
  • Capacity: 64GB
  • Connection: LRDIMM 288-pin
  • Speed: 2666MHz
  • Data Integrity: ECC
Product codes
Kingston DDR4 64 GB LRDIMM 288-pin 2666 MHz / PC4-21300 CL19 1.2 V Load-Reduced ECC
Product Description Kingston - DDR4 - module - 64 GB - LRDIMM 288-pin - 2666 MHz / PC4-21300 - LRDIMM
Product Type Memory module
Capacity 64 GB
Memory Type DDR4 SDRAM - LRDIMM 288-pin
Upgrade Type System specific
Data Integrity Check ECC
Speed 2666 MHz (PC4-21300)
Latency Timings CL19
Features Quad rank, Load-Reduced
Voltage 1.2 V
Lead Plating Gold
OEM Manufacturer Equivalent Part Number HP 815101-B21
Designed For HPE Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10, Medium Solution with HPE ProLiant DL360 Gen10, Small Solution with HPE ProLiant DL360 Gen10; ProLiant DL180 Gen10, DL325 Gen10, DL360 Gen10, DL380 Gen10, DL385 Gen10, DL388 Gen10, DL560 Gen10, DX380 Gen10, ML350 Gen10
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£441.15
