Kingston manufacture the most reliable memory you can buy for a Cisco Server. Kingstons legendary reputation is built around reliable memory, that will power your Cisco server with ease, whether it be for minimal day hours or an enviroment that requires 24/7 uptime all year round. Kingston's legendary reputation is also reflected with the peace of mind of a full lifetime warranty on this Cisco compatible memory module.
Product Description | Kingston - DDR4 - 64 GB - LRDIMM 288-pin - LRDIMM | Product Type | RAM memory | Capacity | 64 GB | Memory Type | DDR4 SDRAM - LRDIMM 288-pin | Upgrade Type | System specific | Data Integrity Check | ECC | Speed | 2400 MHz (PC4-19200) | Latency Timings | CL17 | Features | Quad rank, Load-Reduced | Voltage | 1.2 V | Lead Plating | Gold | OEM Manufacturer Equivalent Part Number | Cisco UCS-ML-1X644RV-A | Manufacturer Warranty | Limited lifetime warranty (Russia - 10 years) | Designed For | Cisco UCS C220 M4S, S3260, Smart Play 8 C240, Smart Play C220 M4, SmartPlay C220 M4S, SmartPlay Select B200 M4, SmartPlay Select C220 M4, SmartPlay Select C220 M4S, SmartPlay Select C220 M4SX, SmartPlay Select C240 M4, SmartPlay Select C240 M4L, SmartPlay Select C240 M4S, SmartPlay Select C240 M4SX |
General | |
Capacity | 64 GB |
Memory | |
Type | DRAM |
Technology | DDR4 SDRAM |
Form Factor | LRDIMM 288-pin |
Module Configuration | 8192 x 72 |
Voltage | 1.2 V |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty (Russia - 10 years) |
Compatibility Information | |
Designed For | Cisco UCS C220 M4S (Not sold Standalone), S3260 Storage Server Base Chassis, Smart Play 8 C240 M4 SFF Entry Plus (Tracer), Smart Play C220 M4 SFF Performance, SmartPlay Select B200 M4 Advanced 2 (Tracer), SmartPlay Select B200 M4 Advanced 4 (Tracer), SmartPlay Select B200 M4 Advanced 5 (Tracer), SmartPlay Select B200 M4 Basic 1 (Tracer), SmartPlay Select B200 M4 High Core 1 (Tracer), SmartPlay Select B200 M4 High Core 2 (Tracer), SmartPlay Select B200 M4 Standard 1 (Tracer), SmartPlay Select C220 M4 Storage Bundle 5, SmartPlay Select C220 M4S, SmartPlay Select C220 M4S (Not sold Standalone ), SmartPlay Select C220 M4S Advanced 1 (Tracer), SmartPlay Select C220 M4S Advanced 3, SmartPlay Select C220 M4S Basic 2, SmartPlay Select C220 M4S High Core 1, SmartPlay Select C220 M4S High Core 2, SmartPlay Select C220 M4S Standard 1 (Tracer), SmartPlay Select C220 M4S Standard 2, SmartPlay Select C220 M4SX Performance 1, SmartPlay Select C220 M4SX Performance 2, SmartPlay Select C220 M4SX Performance 3, SmartPlay Select C240 M4L, SmartPlay Select C240 M4L High Frequency 1 (Not Sold Standalone), SmartPlay Select C240 M4L High Frequency 2 (Not Sold Standalone), SmartPlay Select C240 M4L High Frequency 2 (Tracer), SmartPlay Select C240 M4S Advanced 1, SmartPlay Select C240 M4S Advanced 2, SmartPlay Select C240 M4S Basic 1, SmartPlay Select C240 M4S High Core 1, SmartPlay Select C240 M4S High Core 2, SmartPlay Select C240 M4S Standard 1, SmartPlay Select C240 M4S Standard 2, SmartPlay Select C240 M4S Standard 3, SmartPlay Select C240 M4SX, SmartPlay Select C240 M4SX Advanced 1 (Tracer), SmartPlay Select C240 M4SX Basic 1, SmartPlay Select C240 M4SX High Core 1, SmartPlay Select C240 M4SX High Frequency 1 (Tracer), SmartPlay Select C240 M4SX High Frequency 2 (Tracer), SmartPlay Select C240 M4SX Medium, SmartPlay Select C240 M4SX Performance 2, SmartPlay Select C240 M4SX Standard 1 |
