Kingston 64GB DDR4 LRDIMM 288-pin 2400 MHz/PC4-19200 CL17 1.2...
Kingston 64GB DDR4 LRDIMM 288-pin 2400 MHz/PC4-19200 CL17 1.2V Load-Reduced ECC
Product codes
Kingston manufacture the most reliable memory you can buy for a HP Compaq Server. Kingstons legendary reputation is built around reliable memory, that will power your HP Compaq server with ease, whether it be for minimal day hours or an enviroment that requires 24/7 uptime all year round. Kingston's legendary reputation is also reflected with the peace of mind of a full lifetime warranty on this HP Compaq compatible memory module.
Product Description Kingston - DDR4 - 64 GB - LRDIMM 288-pin - LRDIMM
Product Type RAM memory
Capacity 64 GB
Memory Type DDR4 SDRAM - LRDIMM 288-pin
Upgrade Type System specific
Data Integrity Check ECC
Speed 2400 MHz (PC4-19200)
Latency Timings CL17
Features Quad rank, Load-Reduced
Voltage 1.2 V
Lead Plating Gold
OEM Manufacturer Equivalent Part Number HP 805358-B21, HP 819413-001
Manufacturer Warranty Limited lifetime warranty (Russia - 10 years)
Designed For HPE Apollo 4200 Gen9, 4520 Gen9; ProLiant BL660c Gen9, DL160 Gen9, DL180 Gen9, DL360 Gen9, DL380 Gen9, DL388 Gen9, DL560 Gen9, DL580 Gen9, DL80 Gen9, WS460c Gen9, XL230a Gen9, XL250a Gen9, XL260a Gen9, XL270d Gen9, XL2x260; SimpliVity 380 Gen9; Synergy 480 Gen9, 620 Gen9, 660 Gen9, 680 Gen9
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
