Kingston 64GB IronKey D300 FIPS 140-2 Level 3 Secure USB 3.0...
Kingston 64GB IronKey D300 FIPS 140-2 Level 3 Secure USB 3.0 Drive
£300.38
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Advanced level of security that builds on the features that made IronKey well-respected
  • Rugged and secure casing that meets IronKey standards
  • Fast data transfers that use the latest in NAND Flash and controller technology
  • Customizable
  • Easy to use
Product codes
Kingston’s IronKeyTM D300 USB Flash drive features an advanced level of security that builds on the features that made IronKey well-respected to safeguard sensitive information. It’s FIPS 140-2 Level 3 certified, with 256-bit AES hardware encryption in XTS mode. For added peace of mind, the drive uses digitally signed firmware, making it immune to BadUSB, and it enforces complex password protection with minimum characteristics to prevent unauthorised access. Encryption and decryption is done on the drive, with no trace left on the host system, and the drive locks down and reformats after 10 invalid attempts to protect against brute force attacks.
Rugged and secure, IronKey D300 has a zinc casing and tamper-evident epoxy seal for physical security, so you can rest assured the drive will hold up, even in the most demanding situations. It’s customisable, easy to use and waterproof up to 4 feet, conforming to IEC 60529 IXP8. SuperSpeed (USB 3.0) technology means that you don’t have to compromise speed for security; IronKey D300 allows for fast data transfers, and by adding Kingston’s expertise in Flash memory and the latest in NAND Flash and controller technology, you can be confident in a solution that will be around for years to come.
  • Customizable
  • Easy to use
IronKey D300 - USB flash drive - 64 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
64 GB
Hardware Encryption
Encryption Algorithm
FIPS 140-2 Level 3, 256-bit AES-XTS
NAND Flash
Linux 2.6.x or later, Microsoft Windows Vista SP2, Microsoft Windows 7 SP1, Windows 8 / 8.1 / 10, Apple MacOS X 10.9.x - 10.11.x
5 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kingston 64GB IronKey...
£300.38
