Kingston 64GB IronKey W700 WTG FIPS USB 3.0
Key features
  • Mobilize with windows to go
  • Protect workspaces with military-grade security
  • Comply with strict data security mandates
  • Depend on ironkey drives built to last
  • Workspaces that keep your people working
Product codes
Today’s organizations are employing more mobile workers than ever before. Field personnel, consultants and teleworkers all need a mobile computing environment that gives them access to corporate applications and data, without the burden or expense of lugging a laptop. For many enterprises, that environment is Microsoft Windows To Go, a complete Windows 8 Enterprise workspace that can be booted directly from a USB flash drive or other storage device to run on any PC1, regardless of operating system. With Windows To Go, you can: • Provide your users with an imaged and fully functional version of Windows 8 Enterprise. • Distribute mobile work environments that mirror your corporate desktop. • Ensure employees, partners and contractors are using mobile workspaces created and managed by IT. Not every mobile Windows solution is created equal. And when you’re working with corporate data and applications, you need a solution you can trust. Now there’s IronKey Workspace W700 — the drive certified by Microsoft for Windows To Go that delivers a true Windows 8 desktop embedded in a trusted IronKey USB flash drive.
Product Description IronKey Workspace W700 - USB flash drive - Windows To Go certified - 64 GB
Product Type USB flash drive
Interface Type USB 3.0
Storage Capacity 64 GB
Hardware Encryption Yes
Encryption Algorithm FIPS 140-2 Level 3, 256-bit AES, 256-bit AES-XTS
OS Required Microsoft Windows 7 or later
Windows To Go Certification Yes
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kingston 64GB IronKey...
