Kingston 8GB 2133MHz DDR4 ECC Reg CL15 DIMM DR x8 w/TS
Product codes
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Product Description Kingston ValueRAM - DDR4 - 8 GB - DIMM 288-pin - registered with parity
Product Type RAM memory
Capacity 8 GB
Memory Type DDR4 SDRAM - DIMM 288-pin
Upgrade Type Generic
Data Integrity Check ECC
Speed 2133 MHz (PC4-17000)
Latency Timings CL15 (15-15-15)
Features Temperature monitoring, dual rank, On-Die Termination (ODT), Serial Presence Detect (SPD), sixteen banks, registered with parity
Voltage 1.2 V
Lead Plating Gold
Manufacturer Warranty Limited lifetime warranty (Russia - 10 years)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kingston 8GB 2133MHz D...
