Kingston 8GB 2400MHz DDR4 ECC CL17
£42.24
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
  • Type: DDR4 SDRAM
  • Capacity: 8GB
  • Connection: DIMM 288-pin
  • Speed: 2400MHz
  • Data Integrity: ECC
Product codes
Kingston Server Premier is designed specifically for mission-critical server systems that require maximum uptime and stability. Server Premier Modules are built using the same components every time and include advanced product change notification (PCN). PCN ensures ample time for qualification and testing at the customer site. With Server Premier, you can expect the same degree of reliability and performance that IT professionals worldwide have come to depend on from Kingston memory.
Product Description Kingston Server Premier - DDR4 - 8 GB - DIMM 288-pin - unbuffered
Product Type RAM memory
Capacity 8 GB
Memory Type DDR4 SDRAM - DIMM 288-pin
Upgrade Type Generic
Data Integrity Check ECC
Speed 2400 MHz (PC4-19200)
Latency Timings CL17
Features Single rank, unbuffered
Voltage 1.2 V
Lead Plating Gold
Manufacturer Warranty Limited lifetime warranty (Russia - 10 years)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Kingston 8GB 2400MHz D...
£42.24
