Kingston 8GB DDR4 2400MHz CL17 DIMM Memory
£33.67
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Type: DDR4 SDRAM
  • Capacity: 8GB
  • Connection: DIMM 288-pin
  • Speed: 2400MHz
  • Data Integrity: Non-ECC
Product codes
Kingston - DDR4 - 8 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - CL17 - 1.2 V - unbuffered - non-ECC
Product Description Kingston - DDR4 - 8 GB - DIMM 288-pin - unbuffered
Product Type RAM memory
Capacity 8 GB
Memory Type DDR4 SDRAM - DIMM 288-pin
Upgrade Type Generic
Data Integrity Check Non-ECC
Speed 2400 MHz (PC4-19200)
Latency Timings CL17
Features Single rank, unbuffered
Voltage 1.2 V
Lead Plating Gold
Manufacturer Warranty Limited lifetime warranty (Russia - 10 years)
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: CPBK 041486
£20.32
product
Ref: CPBK 041486
Accessories
Packaging
Functional
Software
Manuals
£20.32
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Kingston 8GB DDR4 2400...
£33.67
