Kingston 8GB DDR4 2666MHz ECC Memory
£47.61
11 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
  • Type: DDR4 SDRAM
  • Capacity: 8GB
  • Connection: DIMM 288-pin
  • Speed: 2666MHz
  • Data Integrity: ECC
Product codes
Kingston DDR4 8 GB DIMM 288-pin 2666 MHz / PC4-21300 CL19 1.2 V registered ECC for Lenovo ThinkSystem SD530; SN850; SR550; SR570; SR590; SR630; SR650; SR850; SR860; ST550
Product Description Kingston - DDR4 - module - 8 GB - DIMM 288-pin - 2666 MHz / PC4-21300 - registered
Product Type Memory module
Capacity 8 GB
Memory Type DDR4 SDRAM - DIMM 288-pin
Upgrade Type System specific
Data Integrity Check ECC
Speed 2666 MHz (PC4-21300)
Latency Timings CL19
Features Registered
Voltage 1.2 V
Lead Plating Gold
OEM Manufacturer Equivalent Part Number Lenovo 7X77A01301
Manufacturer Warranty Limited lifetime warranty (Russia - 10 years)
Designed For Lenovo ThinkAgile HX1321 Certified Node; HX2320 Appliance; HX2321 Certified Node; ThinkAgile VX 1U Certified Node; 2U Certified Node; 2U4N Certified Node; ThinkAgile VX2320 Appliance; VX3320 Appliance; VX3520-G Appliance; VX3720 Appliance; VX5520 Appliance; VX7520 Appliance; ThinkSystem SE350; SR570
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£47.61
