Kingston 8GB microSD UHS-I Industrial Temperature with SD Ada...
Kingston 8GB microSD UHS-I Industrial Temperature with SD Adaptor
£9.51
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Industrial-grade features
  • UHS-I interface
  • MLC NAND
  • Type: microSDHC UHS-I Memory Card
  • Capacity: 8GB
  • SD Speed Class: UHS Class 1 / Class10
  • Stock Status: In Stock
Product codes
Kingston's industrial temperature microSD UHS-I has a wide operating temperature rating, making it suitable for harsh environments. It high operating temperature rating means it stands up to extreme heat in the desert and in test and measurement situations where standard microSD cards may fail, while its low operating temperature rating allows for use in below freezing weather, where equipment may be left outside for extended periods of time. Its high insertion rating is ideal for applications in which the card will be frequently accessed and removed from host devices, and its MLC NAND allows for large amounts of data to be written to the card.
With UHS-I speeds, the card is ideal for applications requiring greater bandwidth when recording large datasets. Higher sustained write speeds ensure data integrity by reducing transmission stutter, and the card also offers faster upload times when transferring files to a PC.
Product Description Kingston - flash memory card - 8 GB - microSDHC UHS-I
Product Type Flash memory card
Form Factor microSDHC UHS-I Memory Card
Storage Capacity 8 GB
Speed Rating UHS Class 1 / Class10
Technology MLC NAND Flash
Included Memory Adapter microSDHC to SD adapter
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kingston 8GB microSD U...
£9.51
