Kingston 960GB UV500 M.2 2280 6GB/s SSD
£125.94
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Ideal for desktops and notebooks
  • Encrypted protection
  • Amazingly fast
  • Form Factor: M.2 2280 (double-sided)
  • Capacity: 960GB
  • Interface: Serial ATA-600
  • Type: Internal hard drive
  • Stock Status: In Stock
Product codes
Kingston's UV500 family of solid-state drives dramatically improves the responsiveness of your existing system with incredible boot, loading and transfer times. Powered by a Marvell Dean controller combined with 3D NAND Flash for read and write speeds up to 520 MB/s and 500 MB/s, this SSD is faster for better performance, ultra-responsive multitasking and an overall faster system. UV500 provides end-to-end data protection, supports 256-bit AES hardware-based encryption and TCG Opal 2.0 security management solutions. More reliable and durable, UV500 is built with NAND Flash semiconductor memory. There are no moving parts, making it far less likely to fail. It is also cooler and quieter, and its shock and vibration resistance makes it ideal for notebooks and other mobile computing devices.
Product Description Kingston UV500 - solid state drive - 960 GB - SATA 6Gb/s
Type Solid state drive - internal - End-to-end data protection, 3D NAND Technology, Marvell 88SS1074 controller
Capacity 960 GB
Hardware Encryption Yes
Encryption Algorithm 256-bit AES
NAND Flash Memory Type 3D triple-level cell (TLC)
Form Factor M.2 2280 (double-sided)
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Features End-to-end data protection, 3D NAND Technology, Marvell 88SS1074 controller
Dimensions (WxDxH) 22 mm x 80 mm x 3.5 mm
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kingston 960GB UV500 M...
£125.94
