Kingston DDR3 16GB 1600MHz/PC3-12800 Registered ECC Low Volta...
Kingston DDR3 16GB 1600MHz/PC3-12800 Registered ECC Low Voltage Module
£184.65
Delivery:
Product codes
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR3L - 16 GB - DIMM 240-pin - registered
RAM memory
16 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3L-12800)
Latency Timings
CL11
Dual rank, Low Voltage, registered
Voltage
1.35 V
Lead Plating
Gold
HP 664692-001, HP 713985-B21, HP 713985-S21, HP 715284-001, HP 713756-081
Limited lifetime warranty (Russia - 10 years)
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kingston DDR3 16GB 160...
£184.65
