Kingston DDR3L 4 GB SO-DIMM 204-Pin 1600 MHz / PC3L-12800
£20.64
20 in stock
Delivery:
Standard: 1-3 working days
  • Type: DDR3L SDRAM
  • Capacity: 4GB
  • Connection: SO-DIMM 204-pin
  • Speed: 1600MHz
  • Data Integrity: Non-ECC
Product codes
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Product Description Kingston - DDR3L - 4 GB - SO-DIMM 204-pin - unbuffered
Product Type RAM memory
Capacity 4 GB
Memory Type DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type Generic
Data Integrity Check Non-ECC
Speed 1600 MHz (PC3L-12800)
Latency Timings CL11
Features Low Voltage, unbuffered
Voltage 1.35 V
Lead Plating Gold
OEM Manufacturer Equivalent Part Number Panasonic CF-WMBA1104G, HP 691740-001, HP H6Y75AA, HP H6Y75UT, Toshiba PA5104U-1M4G, Panasonic CF-WMBA1204G, HP D0H47AV, DELL A6950118, DELL A6951103, Panasonic CF-WMBA1304G, Panasonic CF-BAX04GI, Lenovo 0B47380, HP H6Y75ET, Panasonic CF-BAS04GU
Manufacturer Warranty Limited lifetime warranty (Russia - 10 years)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Kingston DDR3L 4 GB SO...
£20.64
