Kingston MobileLite Duo 3C microSD Reader - USB 3.1 Type-C /...
Kingston MobileLite Duo 3C microSD Reader - USB 3.1 Type-C / Type-A
£8.24
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Compact, lightweight microSD card reader
  • Dual interface accommodates USB Type-A and USB Type-C ports
  • Metal casing provides rugged portability
  • For devices with a limited number of expansion ports
  • Supported Formats: microSD, microSDHC UHS-I Memory Card, microSDXC UHS-I Memory Card
  • Interface: USB 3.1 Gen 1
  • Stock Status: In Stock
Product codes
Kingston's MobileLite Duo 3C is a microSD card reader that works well with the latest products with USB Type-C ports, as well as devices that use USB Type-A. This versatile device has a small metallic form factor so it easily fits in a pocket, handbag or backpack and is ideal for personal or professional use. Offload files and photos quicker using the USB Type-C port, which has a universal connector that plugs in easily. This versatile device reads microSD/ SDHC/SDXC, UHS-I and supports the latest card speeds.
MobileLite Duo 3C is compliant with the USB 3.1 Gen 11 (USB 3.0) specification and delivers incredible performance to save time when transferring videos, photos and other large file sizes. It is backwards compatible with USB 2.0 ports to allow users to migrate to USB 3.0 in the future, using one card reader. MobileLite Duo 3C is backed by a two-year warranty, free technical support and legendary Kingston reliability.
Product Description Kingston MobileLite Duo 3C - card reader - USB 3.1 Gen 1
Product Type Card reader - external
Supported Memory Cards microSD, microSDHC UHS-I Memory Card, microSDXC UHS-I Memory Card
Host Interface USB 3.1 Gen 1
Designed For Apple MacBook (Early 2015, Early 2016, Mid 2017); MacBook Air (Late 2018); MacBook Pro (Late 2016, Mid 2017, Mid 2018)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kingston MobileLite Du...
£8.24
