Kingston SSDNow 240GB M.2 SATA 6Gbps Single Side
Key features
  • Multi-purpose SFF connector replaces small mSATA and mini-PCIe slots
  • Integrates easily into designs with M.2 connectors
  • Ideal for thin and light systems
  • Provides high capacity
Product codes
Next-generation SSD technology
Kingston’s M.2 SATA G2 SSD is a thin and compact, caseless internal solid-state drive that combines high capacity with low power consumption to serve as a reliable caching device or primary storage for the O/S and applications. Suitable for desktop motherboards that use the Intel 9x chipset and popular small-form-factor (SFF) PCs including ultrabooks, notebooks and tablets, the M.2 2280 SATA G2 SSD easily integrates into designs with M.2 connectors and is ideal for system builders and DIY end users.
Lighter weight than a cased SSD, the M.2 SATA G2 SSD optimises performance with advanced garbage collection, wear-levelling and TRIM support to keep performance consistent over the life of the drive.(1) DevSleep, a recent addition to the SATA specification, is an efficient power management option that minimises power consumption and extends battery life. Firmware-based power loss protection maintains data integrity and ensures that data in the cache is constantly flushed and hardened to NAND to enable the drive to recover in the event of an unsafe shutdown.
The complimentary Kingston SSD Manager (KSM) monitors warranty status and SSD health via the Kingston website. The M.2 SATA G2 SSD is backed by a limited five-year warranty(2), free technical support and legendary Kingston® reliability.
  • Space-saving caseless design fits ultra-thin computing applications
  • Capacities of up to 480GB(3)
  • M.2 Gen 2 SSDs are backed by a limited five-year warranty(2)
1. Based on "out-of-box performance" using a SATA Rev. 3.0 motherboard. Speed may vary due to host hardware, software and usage. IOMETER random 4k random read/write is based on 8GB partition.
2. Limited warranty based on five years or SSD "Life Remaining" which can be found using the Kingston SSD Manager (kingston.com/SSDManager). A new, unused product will show a wear indicator value of one hundred (100), whereas a product that has reached its endurance limit of program erase cycles will show a wear indicator value of one (1). See kingston.com/wa for details.
3. Some of the listed capacity on a Flash storage device is used for formatting and other functions and is thus not available for data storage. As such, the actual available capacity for data storage is less than what is listed on the products. For more information, go to Kingston’s Flash memory Guide at kingston.com/flashguide.
Kingston SSDNow - solid state drive - 240 GB - SATA 6Gb/s
Solid state drive - internal
240 GB
M.2 2280
SATA 6Gb/s
Data Transfer Rate
600 MBps
TRIM support, Wear Leveling Support, Advanced Garbage Collection, DevSleep mode
22 mm x 80 mm x 3.5 mm
5.99 g
5 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kingston SSDNow 240GB...
