Kingston's A400 solid-state drive dramatically improves the responsiveness of your existing system with incredible boot, loading and transfer times compared to mechanical hard drives. Powered by a controller for read and write speeds of up to 500 MB/s and 450 MB/s, this SSD is 10x faster than a traditional hard drive for higher performance, ultra-responsive multi-tasking and an overall faster system.
Product Description | Kingston A400 - SSD - 120 GB - SATA 6Gb/s | Type | Solid state drive - internal | Capacity | 120 GB | NAND Flash Memory Type | Triple-level cell (TLC) | Form Factor | 2.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Dimensions (WxDxH) | 69.9 mm x 100 mm x 7 mm | Weight | 41 g | Manufacturer Warranty | 3-year warranty |
General | |
Device Type | Solid state drive - internal |
Capacity | 120 GB |
Width | 69.9 mm |
Depth | 100 mm |
Height | 7 mm |
Weight | 41 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 500 MBps (read) / 320 MBps (write) |
Reliability | |
MTBF | 1,000,000 hours |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s - 7 pin Serial ATA |
Compatible Bay | 2.5" |
Power | |
Power Consumption | 0.195 Watt (idle) , 0.279 Watt (average) , 0.642 Watt (read) , 1.535 Watt (write) |
Miscellaneous | |
Compliant Standards | ISO 9001, SGS |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 85 °C |
Vibration Tolerance (operating) | 2.17 g @ 7-800 Hz |
Vibration Tolerance (non-operating) | 20 g @ 10-2000 Hz |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
