Kingston SSDNow A400 480GB SATA 6Gb/s SSD
£46.30
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Hard drive replacement
  • For desktops and notebooks
  • Revive older systems
  • Form Factor: 2.5"
  • Capacity: 480GB
  • Interface: Serial ATA-600
  • Type: Internal hard drive
  • Stock Status: In Stock
Product codes
Pro
Kingston’s A400 solid-state drive dramatically improves the responsiveness of your existing system with incredible boot, loading and transfer times compared to mechanical hard drives. Powered by a latest-gen controller for read and write speeds of up to 500MB/s and 450MB/s1, this SSD is 10x faster than a traditional hard drive1 for higher performance, ultra-responsive multi-tasking and an overall faster system.
Also more reliable and durable than a hard drive, A400 is built with Flash memory. There are no moving parts, making it less likely to fail than a mechanical hard drive. It’s also cooler and quieter, and its shock and vibration resistance makes it ideal for notebooks and other mobile computing devices.
A400 is available in Multiple capacities from 120GB–480GB2 to give you all the space you need for applications, videos, photos and other important documents. You can also replace your hard drive or a smaller SSD with a drive big enough to hold all your files.
This SSD is designed for use in desktop and notebook computer workloads, and is not intended for server environments.
Product Description Kingston SSDNow A400 - solid state drive - 480 GB - SATA 6Gb/s
Type Solid state drive - internal
Capacity 480 GB
NAND Flash Memory Type Triple-level cell (TLC)
Form Factor 2.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Dimensions (WxDxH) 69.9 mm x 100 mm x 7 mm
Weight 41 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kingston SSDNow A400 4...
£46.30
