ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Product Description | Kingston ValueRAM - DDR4 - 64 GB: 4 x 16 GB - DIMM 288-pin - registered with parity | Product Type | RAM memory | Capacity | 64 GB: 4 x 16 GB | Memory Type | DDR4 SDRAM - DIMM 288-pin | Upgrade Type | Generic | Data Integrity Check | ECC | Speed | 2400 MHz (PC4-19200) | Latency Timings | CL17 (17-17-17) | Features | Temperature monitoring, single rank, On-Die Termination (ODT), Serial Presence Detect (SPD), sixteen banks, registered with parity | Voltage | 1.2 V | Lead Plating | Gold | Pricing Type | Intel Memory Validation Program | Manufacturer Warranty | Limited lifetime warranty (Russia - 10 years) |
General | |
Memory | |
Type | DRAM |
Technology | DDR4 SDRAM |
Form Factor | DIMM 288-pin |
Module Height (inch) | 1.23 |
Module Configuration | 2048 x 72 |
Chips Organization | 2048 x 4 |
Voltage | 1.2 V |
Miscellaneous | |
Colour Category | Green |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty (Russia - 10 years) |
