LaCie 2TB Rugged Thunderbolt USB-C + USB 3.0
£166.36
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Large project storage
  • USB-C for universal connectivity
  • Bus powered for complete mobility
  • Shock, dust, and water resistant for all-terrain use
  • Form Factor: 2.5"
  • Capacity: 2TB
  • Stock Status: In Stock
Product codes
Legendary Rugged toughness meets USB-C compatibility, blazing-fast Thunderbolt speeds. Also featuring a tethered cable and IP54-rated resistance to the elements, this Rugged drive means you don't have to compromise between durability, mobility, and speed.
Product Description LaCie Rugged Thunderbolt USB-C - hard drive - 2 TB - USB 3.1 Gen 1 / Thunderbolt 3
Type Hard drive - external (portable) - shock resistant, water resistant, dust-proof, crush-resistant
Capacity 2 TB
Interface USB 3.1 Gen 1 / Thunderbolt 3 - USB-C
Features Shock resistant, water resistant, dust-proof, crush-resistant
Power Source USB bus
Dimensions (WxDxH) 8.98 cm x 14.01 cm x 2.5 cm
Weight 400 g
Localisation Worldwide
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LaCie 2TB Rugged Thund...
£166.36
