LaCie 2TB Rugged Triple FW800 & USB 3.0 2.5" Portabl...
LaCie 2TB Rugged Triple FW800 & USB 3.0 2.5" Portable Drive
Key features
  • Triple interface for the best performance
  • Four levels of rugged protection
  • A fifth level of data security
  • Automatic backup
  • Password protection
  • 40% energy savings
  • Enhanced speed and connectivity
  • AES 256-bit encryption protection
  • Drop-resistant up to two meters
Product codes
The LaCie Rugged Triple hard disk provides universal connectivity: you've got the superior speeds of USB 3.0. Additionally, you can use the LaCie Mac USB 3.0 driver to improve data transfer speed on your Mac. Whether your goal is super speed or complete compatibility, the Rugged Triple has everything you need.
It conforms to military standard 810-F, and can support drops from up to two meters. It helps you carry your files with confidence, no matter where the road takes you, thanks to its shock-absorbing sleeve, aluminum anti-scratch casing, internal rubber bumpers, and a 1000 G shock-resistant hard drive. Calculations are based on average read time.
LaCie AES 256-bit encryption software comes standard with the Rugged Triple. AES 256-bit encryption technology is one of the most robust on the market today, and makes the Rugged Triple more secure than ever. With LaCie Private-Public software built-in, it's easy to make sure that your files are secure and protected, no matter where you go. Automatic eco mode lowers the power consumption by up to 40% when not in use, increasing the battery life of your notebook or laptop.
Product Description LaCie Rugged Triple - hard drive - 2 TB - FireWire 800 / USB 3.0
Type Hard drive - external (portable) - shock resistant, hardware encryption, rugged, automatic backup
Capacity 2 TB
Hardware Encryption Yes
Encryption Algorithm 256-bit AES
Interface FireWire 800 / USB 3.0
Data Transfer Rate 800Mbps(FireWire800)/5Gbps(USB 3.0)
Features Shock resistant, hardware encryption, rugged, automatic backup, 256-bit AES
Dimensions (WxDxH) 90 mm x 145 mm x 28 mm
Weight 260 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LaCie 2TB Rugged Tripl...
