LaCie 2TB Rugged USB-C + USB 3.0 Portable Hard Drive
£120.54
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Form Factor: 2.5"
  • Capacity: 2TB
  • Stock Status: In Stock
Product codes
Beyond being rain, drop, and crush resistant, the LaCie Rugged USB-C is also backwards compatible with USB 3.0 and USB 2.0.
Product Description LaCie Rugged USB-C - hard drive - 2 TB - USB 3.1 Gen 1
Type Hard drive - external (portable) - rugged pocket-sized design, rain-resistant, impact-resistant, crush-resistant
Capacity 2 TB
Interface USB 3.1 Gen 1 - USB-C
Data Transfer Rate 5.0 Gbps (USB 3.1) / 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Features Rugged pocket-sized design, rain-resistant, impact-resistant, crush-resistant
Power Source USB bus
Dimensions (WxDxH) 86 mm x 135.1 mm x 18.7 mm
Weight 100 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LaCie 2TB Rugged USB-C...
£120.54
