LaCie 36TB 6big RAID Thunderbolt3 & USB 3.1 [7200] Enterp...
LaCie 36TB 6big RAID Thunderbolt3 & USB 3.1 [7200] Enterprise
£2,851.33
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • The absolute fastest I/O
  • For lightning-fast video workflows
  • For your smart workspace
  • Bigger in every way, except in footprint
Product codes
Think bigger - LaCie's got you covered. With up to 36TB of capacity on your desktop, and RAID 5/6, the LaCie 6big Thunderbolt 3 lets you rein in the stampede of data from ultra high resolution cameras.
Product Description LaCie 6big Thunderbolt 3 STFK36000400 - hard drive array
Device Type Hard drive array
Total Array Capacity 36 TB
Interface USB 3.1, Thunderbolt 3
Installed Devices / Modules Qty 6 (installed) / 6 (max)
Supported Drives SATA
Built-in Devices Led panel
Storage Controller RAID RAID 0, 1, 5, 6, 10, 50
Hard Drive 6 x 6 TB HDD - hot-swap - Enterprise Class Reliability, 24x7 continuous operation
OS Required Apple MacOS X 10.10 or later, Windows 8 or later
Power AC 120/230 V - 50/60 Hz
Dimensions (WxDxH) 16.1 cm x 22.5 cm x 23.7 cm
Weight 9.9 kg
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LaCie 36TB 6big RAID T...
£2,851.33
