LaCie 3TB d2 Quadra v3 7200RPM FW800/USB2/ESATA-300
Key features
  • Quadruple interface for full PC / Mac compatibility
  • Superior burst transfer rates up to 115 MB/s (eSATA)
  • Sturdy aluminum d2 heat sink and ergonomic design
  • Advanced features, plug and play
Product codes
Fully loaded with all the best interfaces - eSATA 3Gbits, FireWire 800, FireWire 400 and USB 2.0 - this all-in-one professional hard disk offers universal connectivity for PC and Mac users. For easy setup, the LaCie Setup Assistant helps format according to your needs. The unique, fanless aluminum heat sink design with 60 % more surface area for heat dissipation keeps it quiet and safe. With the LaCie Shortcut Button, easily launch any application in one push. Perfect for digital content creation, audio / video editing, DVD authoring, and web animation, etc., the d2 Quadra can handle multiple demanding professional tasks. It can be daisy-chained via FireWire or connected to your DV camera and is even bootable in FireWire for Mac and in eSATA for Mac / PC.
Product Description LaCie d2 Quadra Hard Disk - hard drive - 3 TB - FireWire 800 / USB 3.0 / eSATA-300
Type Hard drive - external (desktop)
Capacity 3 TB
Interface FireWire 800 / USB 3.0 / eSATA-300
Data Transfer Rate 800Mbps(FireWire800)/5Gbps(USB 3.0)/3Gbps(eSATA)
Spindle Speed 7200 rpm
Power Source Included AC adapter
Dimensions (WxDxH) 18.3 cm x 16.8 cm x 6 cm
Weight 1.7 kg
Microsoft Certification Compatible with Windows 7
Manufacturer Warranty 3 years warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LaCie 3TB d2 Quadra v3...
