LaCie 5TB Rugged Thunderbolt USB-C + USB 3.0 portable extern
£232.68
11 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Thunderbolt speeds
  • USB-C for universal connectivity
  • Bus powered for complete mobility
  • Shock, dust, and water resistant for all-terrain use
  • Form Factor: 2.5"
  • Capacity: 5TB
  • Stock Status: In Stock
Product codes
Rugged toughness meets USB-C compatibility and blazing-fast Thunderbolt speeds. Also featuring a tethered cable and resistance to the elements, this Rugged drive means you don't have to compromise between durability, mobility, and speed.
Product Description LaCie Rugged Thunderbolt USB-C STFS5000800 - hard drive - 5 TB - USB 3.1 Gen 1 / Thunderbolt
Type Hard drive - external (portable) - shock resistant, water resistant, dust-proof, crush-resistant
Capacity 5 TB
Interface USB 3.1 Gen 1 / Thunderbolt - USB-C
Features Shock resistant, water resistant, dust-proof, crush-resistant
Power Source USB bus, Thunderbolt bus
Dimensions (WxDxH) 90.9 mm x 148.4 mm x 34 mm
Weight 600 g
Localisation Worldwide
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LaCie 5TB Rugged Thund...
£232.68
