LaCie 6TB d2 Quadra FireWire + USB 3.0 Desktop
£254.44
Delivery:
Key features
  • Universal connectivity and compatibility
  • Professional grade
  • Save space
  • Advanced power modes for energy savings
  • Form Factor: 3.5"
  • Capacity: 6TB
Product codes
With the USB 3.0 interface and huge capacity, the LaCie d2 Quadra desktop drive is the ideal tool for creative professionals who need both fast speeds and large storage capacity. It can handle resource-intensive applications. The d2 Quadra has advanced connectivity with USB 3.0 and FireWire 800 interfaces for daisy chaining, but it is still fully compatible with eSATA, USB 2.0 and FireWire 400. With all of its interfaces, the d2 Quadra has universal connectivity, so it's easy to back up and restore any workstation, no matter the configuration and interfaces. And thanks to the USB 3.0 performance, you can make faster, more frequent backups of your data, keeping it safe and secure.
Product Description LaCie d2 Quadra - hard drive - 6 TB - FireWire 800 / USB 3.0 / eSATA-300
Type Hard drive - external (desktop)
Capacity 6 TB
Interface FireWire 800 / USB 3.0 / eSATA-300
Data Transfer Rate 800Mbps(FireWire800)/5Gbps(USB 3.0)/3Gbps(eSATA)
Spindle Speed 7200 rpm
Power Source Included AC adapter
Dimensions (WxDxH) 4.4 cm x 15.9 cm x 17.2 cm
Weight 2.3 kg
Localisation Worldwide
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LaCie 6TB d2 Quadra Fi...
£254.44
